Hi Tim,
Good move there. on stepping up/away from a “MiFi” device. Some family members of mine decided they would sell their homes and “boondock” for a while. Both signed up for the same exact Verizon post-paid plan. Streaming, email, web browsing and WiFi calling from their T-Mobile phones when no service available were the primary use cases for them.
RV # 1 has a MAX BR1 Mini LTEA (CAT 6 LTE Radio) with the Peplink Mobility 20G antenna (https://download.peplink.com/resources/pepwave_mobility_20g_datasheet.pdf).
RV # 2, went with a Netgear Nighthawk M1 (MR1100, CAT 16 LTE Radio) connected to their built-in Wineguard antenna.
In all areas they traveled in the Western states (starting off in OR) RV # 1 had better signal acquisition and performance. Like you, they were mostly getting lower spectrum - BAND 13 and where available BAND 5. Some areas the Nighthawk would not connect at all whereas the BR1 Mini would. RV #1 also now has Starlink for RV mixed in.
The BR1 Pro CAT 20 is an excellent device. There is also the Br1 Pro 5G which is both mid-Band 5G and CAT 20 4G. The MSRP delta between 5G and the CAT 20 only is roughly $150. So if you are looking to “future proof” the 5G version may be a better choice. Though both may be overkill, depending on your extended use case.
Both pair well with either Mobility 40G or Mobility 42G (omni-directional) however those antennas have the highest gain in the upper Frequency ranges whereas the Maritime 40G is a more balanced gain across the ranges but slightly higher VSWR in the range you’d be operating in. If you have an appetitive for per site adjustments (turning antenna(s) towards tower) and watching the readings while logged into the Peplink router, the IoT 20G (directional) would be a good choice for its higher gain in the both the lower and upper frequencies. Would need 2 x of the IoT 20G for the BR1 Pro’s listed above.
You might also consider the MAX BR1 Mini LTEA -US-T-PRM (CAT 7) as a more economical choice. Add the MAX-BR1-MINI-BD-FP-2Y for a sub $600 setup. Pair with the Mobility or Maritime or IoT 20G antenna.
Toss those Proxicasts.
Lastly, I didn’t cover Carrier Aggregation (CA) here based on your use case and having Starlink but in areas where you can get more than one BAND, CA is awesome for throughput and stability. All models listed above can do, at a minimum of 2 CA up and 2CA down with the BR1 PROs capable of more CA than the BR1 Mini.
Hope this helps!
Beau
(Peplink Partner, Central Oregonian, Traveler of the PNW)
