I have an open ticket on this, figured I’d check if any other users are experiencing a similar issue. Support seems to be completely drawing a blank when I describe it as a “hang” or “driver stall”. They tried taking a stab at signal levels being too high/low (this doesn’t cause the driver to stop working, but ok) or my antennas being faulty (again, not going to cause the driver to get stuck). Then they say the support-only device logs are missing for the event and the diagnostics report I have downloaded “isn’t it” (came from the support tools page, but not useful for diagnostics? Strange.)
What happens is that roughly once a week (but occasionally more often) the 2.4Ghz radio drops followed by the 5Ghz radio 5 seconds later. Neither radio will recover, scan, nor connect to any network any longer. If I go into each radio’s settings and toggle ANY setting then save, the radio comes back to life just fine. I’ve been toggling the power modes since it doesn’t alter anything else. Wait another 7 days to rinse and repeat.
8.3.0 build 5229
