Hey - i know you can switch the wan port to act as lan…
Is is possible to do the opposite and run the second lan port as a second wan so you can have two wired inputs?
Rob
Rob
I’d also like to know this. Alternatively, if I put a switch on the WAN port, would the BR1 pro 5g be able to utilize two wan connections?
Yes you will use the vlan as wan option that is on 8.4+ fw.
Then set the port to access mode for whatever vlan you definded for the vlan as wan.
