I initially setup SL 6-months ago as shown on the attached configuration. Worked fine. I then paused SL service for 4-months and only recently re-activated and having issues running SL through my MAX BR1 PRO 5G.
- when connected via WiFi directly to Starlink router, everything works fine.
- When attached to SL via MAX BR1 PRO 5G router (via Starlink Ethernet Adapter), either
- Speeds are greatly reduced; or
- Will not connect (shown in screen shot); or
- “WAN DNS Failed to Connect” error.
I have replaced the Ethernet cable between the Pepwave router and the SL Ethernet Adapter. Problem improved, but recurred 1-day later.
Thoughts? Maybe Ethernet adapter? Or are there some settings? Thanks in advance -
