I recently purchased the Max BR1 Pro 5G and Maritime 20G Antenna. The Max BR1 Pro 5G has 4 antenna connectors while the Maritime 20G has two antenna cables. My question is which antenna connectors on the Max BR1 Pro 5G (A, B, C, D) do I connect the two antenna cables from the Maritime 20G for best performance? Also, do I use two of the plastic antennas that came with Max BR1 Pro 5G in the remaining two unused antenna connectors? Appreciate any help on this as I can’t find info on this anywhere.
Hi Brian,
What is your router SKU? In case you are using -5GH, then Martin already gave you information. For -5GD please connect to A and C ports.
