How to monitor MAX BR1 connected as follows?
Under System - SNMP, you can set the information to your central SNMP manager.
You can download the SNMP MIB files for you SNMP manager from here:
I already have it configured but it doesn’t work, does the IP Passthrough hano anything to do with it?
IP Passthrough is more to WAN IP assigning method for the device connected behind the BR1. It’s it not related to the SNMP monitoring.
First of all, can you ping the WAN IP from the SNMP server ? Beside that, can you share your BR1 SNMP settings here ?
