I have a Max BR1 MK2 using Starlink for WAN internet connection via direct Cat5E cable with PoE injector for the Starlink dish. Starlink plan is mobile regional, so I have de-prioritized data speeds. BR1 MK2 firmware is last version available. Management IP address for Starlink WAN is 192.168.100.100 / 255.255.255.0 (/24). MTU is set to Auto. Port speed is set to 100 Mbps Full Duplex. Other port speed settings (Auto, 1 Gbps) would severely reduce download speeds to <1 Mbps. I’m assuming the 100 Mbps Full Duplex port speed is the best setting since the router’s max throughput is only rated at 100 Mbps.
With these settings, I’m typically getting between 35-60+ Mbps download speeds via multiple speed tests (Starlink app, Ookla, Fast, Google), but my upload speeds never exceed 1-2 Mbps and are usually under 1 Mbps, which is making voice and video calls unstable or unusable. I know that there is asymmetry in Starlink speeds, but upload speeds from other users are typically 10-25% of download speeds, so I should be seeing at least 3-4 Mbps if not more. And I was getting much better upload speeds when I was using the Starlink router and connecting the BR1 MK2 via wifi WAN. I’m convinced there must be a configuration issue with the BR1 MK2 Starlink WAN that I’m missing. Any advice?
