Is there a way to login to a pepwave BR 1 MK2 remotely, to the admin page? Probably basic, so thank you in advance.
yes add the serial number to incontrol2 , https://incontrol2.peplink.com
Aside from connecting via IC2, you can also enable remote user access and connect via OpenVPN, L2TP with IPsec or PPTP.
Such a connection requires that the unit have a routable IP address.
Go to Advanced>Remote User Access.
Cheers,
Z
Thank you. Is there a way to see the features of the pepwave, like I do locally when I type in the IP? I am trying to be able to see what sims are in play and status of unit remotely to help a friend out on location with one.
Not sure I make a ton of sense.
I found my answer by looking around. Thank you again.
