I have a MAX BR1 MK2 in an RV. I have not used it in 3-4 months. I’m currently in the NC mountains now and it will not connect to cellular. Just states “Obtaining IP address”. Connects to campground Wi-Fi just fine. After two days of trouble shotting with T-Mobile technicians and a new SIM card it still will not connect. They said they can connect to the router. They concluded my router does not support band 7 & 12 and that is all T-Mobile uses in most areas since about July of this year.
Below it states I’m on Band 5
I find it hard to believe the MAX BR1 MK2 no longer works with T-Mobile.
Firmware is 8.2.1
OK so you disagree with their finding? “they concluded my router does not support band 7 & 12 and that is all T-Mobile uses in most areas since about July of this year” ??
Have you used any tools on a different device or looked up public cell tower info to see what bands it has/broadcasts for t-mobile?
I’m not sure what I think yet, just looking for advice here. I plan on taking the router with me to day to Boone to see if it works there. About 45 minutes away and I’m sure different towers.
I have not looked up tower information but will try to figure that out when I return back to the RV.
Update…
Went to Boone and it worked fine. So, I assume it has to do with the towers near the area I am camped at.
According to this coverage map from T-Mobile I am in an area that is supported by a Partner.
Do I have any options with this router? Would a different Pepwave work at in a partner area?
Well, I’ll tell you one way … If you have an iPhone type in 3001#12345# . Hit the icon in the upper right, then hit “serving cell info.” You’ll see the primary band on the next page. - Rick
I assume I do this as if making a call, right?
When I did that, I get a screen that states “Error performing request Unknown Error” Then the only option I get is Dismiss
