I just purchased and configured the add-on, MAX-BR1-MINI-LC-FS “Failover software license and related feature set for BR1-MINI, enables Ethernet and Wi-Fi WAN”
I expected enabling Ethernet WAN would provide Outbound Policy to define load balancing rules between the LTE-A connection and the wired WAN connection, as described in the Pepwave MAX User Manual, and as I have on other Peplink devices. I rebooted and can’t find this functionality.
Also, the BR1 Mini UI seems to imply that multiple WANs can be assigned to the same Priority: “Drag desired (Priority [N]) connections here” and “Only healthy WAN connection(s) with the highest priority will be used for routing traffic”, but if I drag a second WAN in, the other pops down to the next lower priority. Can more than one WAN be assigned to the same priority, and if so, how is traffic divvied up between the two?
Is there a way to use both WANs simultaneously? If not, can I get the license rescinded and refunded?
