I’m relatively new to this type of tech, so this may be a fairly easy question. I just bought a MAX BR1 Mini Surf, and just removed the two sim cards from my Verizon hotspot and AT&T hotspot, thinking I would be good to go. Instead, the sim cards are different sizes; the AT&T fits fine, the Verizon is much smaller and I feel as if the card will be swallowed by the unit if I try to insert it. Is there an adapter (seems unlikely), or do I need to approach Verizon for a new sim card. Thanks in advance …
You just need a sim adapter kit, for example
Thanks aquablue, I appreciate it!
