Max BR1 mini has started resetting 4 or more times each day. I’m on ATT and yesterday upgraded to newest firmware 8.0.2. I’m also using a Poynting MIMO omni antenna. Any suggestions
Here are my signals:
RSSI: -77 > 83 dBm
SINR: 3.2> 7.2 dB
RSRP: -115 dBm
RSRQ: -14.0 dB
Hi - welcome to the forum.
What does the event log say? Is the device resetting or is it failing a health-check I wonder?
If you only have a single cellular connection on this BR1 mini I would disable health-check on the cellular connection.
Event log shows: WAN: Cellular disconnected. Then: WAN: Cellular connected to AT&T (10.38.185.220) in SIM slot A
Health-check is disabled. Should I set it to smart check? I only have 1 sim for ATT.
OK that suggests it is actually losing connection to the tower. Is that IP (10.38.185.220) different than the last time you connected?
Go to InCOntrol2 and look at the wan quality report for that time, does the signal drop off a cliff around when it loses connectivity?
IP is different each time it disconnects. I set a schedule to disconnect at 2pm each night. I’m trying to determine if my problem is with the ATT signal or with my Pepwave.
Thanks!
