So this has been nothing but a trainwreck so far, mainly because at&t prepaid is just horrible. Just know I have access to my prepaid account and show I have 15 Gb of data in the account (this is just atrial run to see if things work properly). Anyway, I have my at&t prepaid sim card in slot A, shows connected to AT&T LTE with a couple bars. The location it shows me at on the dashboard is correct too so I know we have some connectivity of some kind. So under AP i set up my own wifi…give it a name, set the password, set the security policy to WPA-WPA2 - personal, all good there. when I try to connect to the wifi I log in with the password I set then I get this page:
Mind you I have already activated my prepaid sim card, my account shows active and everything. I have already restored all factory settings and set it up again and still get this screen…basically the wifi from the Max BR1 mini is unusable.
Soooo…anyone else had similar problems and figured out haw to make this work or does this thing not work at all with AT&T? The plan is to have a Tmobile prepaid card in slot B also but if I can’t get this to work at all no sense of wasting more of my time on a brick.
Also as a side note, I plug in my laptop to the LAN port of the Max BR1 mini and I have no connectivity to the internet. I tried to run a speed test and it never starts, just says there is a problem with the network. So it really seems that there is an issue with the at&t network with this Max BR1 mini.
