MAX-BR1-MINI-5GN-T-PRM having network stability issues
I have a new MAX-BR1-MINI-5GN-T-PRM connected to RoamLink, StarLink, and local wifi; however, I’m having stability issues. I can directly teather to my iPhone, connect to StarLink, or local wifi and get a much better Internet connection. This is true with and without VPN. I have changed the MTU to 1300 on my MAX-BR1-MINI-5GN. Anyone have advise as to why the Peplink is not giving a stable connection? Also I have upgraded to the Peplink slim antenna.
Seems I have the same issue, I found Br1 Mini 5G does not works reliable with Max antenna.
I have experienced similaires problèmes last years with same set up. Wifi AP is not powerful with your device located in your antenna I mean you just broadcast signal for the birds.
I have noticed that my device is very slow to connect, health check does help and brings more problems.But is important to check both firmware, device and cellular firmware to be updated.
Today I am ok since I am following my signal quality and move the antenna if necessary.
