Having a strange problem with my MAX BR1 LTE.
It worked just fine after i set the PIN and APN for my primary WAN.
After that I rebooted the device and now it connects as it should (strong signal and LTE with IP-adress) and provides a stable WIFI but the access to internet is extremely limited.
For an example I use whatsapp and that works but regular www and other services are dead.
Even tested LAN1/LAN2 with cable to my laptop but still no internet.
Have checked the firewall settings but it looks fine.
Any ideas?
