I have a MAX-BR1 IP55 version on Verizon with a Public IP address.
First of all I bought 7 of these models and all of them come with the Flex AP firmware not the MAX firmware(I have bought and used a MAX-BR1 non ip55 in the past).
Second, I cannot set the port forwarding rules successfully. I first tried port mapping 8080>80 with no success. Then I changed the NAT’d device to use port 8080 and still could not get it to forward with a direct 8080>8080 map. DMZ does work to allow the device on the internet. Please help, what am I doing wrong?
Also is there a flat file I can edit config on for deployment to multiple devices?
Yes it and all my other static IP addresses with Verizon are in the 166.x.x.x range.
DMZ works. Port forwarding/mapping does not.
There is no firewall settings available to me in the Peplink device(Flex AP firmware but with a MAX-BR1 label). It and the other device are the only two devices in the network. It is open on what ever port I set it to.
