Is there an option for IP Passthrough and forwarding via the WAN USB port?
Under the USB WAN, If I try to disable NAT and select IP forwarding it always reverts back to NAT after saving. I do not see any option for IP Passthrough.
Want to set the MAX adapter as Priority-1 and the built-in cellular priority-2 (backup).
IP forwarding & passthrough work as expected through the cellular WAN.
Greg
