Hi - I am swapping out a Max Br1 Mini (HW1) for the latest HW3 variant. The old HW1 had a two pin DC power block and an adapter to plug the wires into. The new HW3 has a 4 pin block, and no adapter other than the AC power block. Where can I find the right adapter plug (and why dont you supply it in the box?) to plug DC power wires into the box?
The cradlepoint one is compatible and quite easy to find.
Thank you. So this would require converting the two wire side to work with this barrel connector right? Is there an adapter that will do that?
Would this work? Amazon.com
Yes that would work fine. It is center pin positive on the DC barrel.
You can also grab a 4-pin molex at mouser.
Double sided, cut in half and you have two cables.
Thanks. A request to Peplink - please include this connector for DC power in the box. Its really annoying when you get something and have to go shopping extensively and wait days to get the items you need to install it (or in this case replace and older product of yours with a newer edition). This wasnt the case with the HW1 - it included the block needed.
This is copy/paste from another post I had replied to but believe the Molex is the correct connector.
Hi, they refer to these as the GPIO (General Purpose Input/Output) connector and in my research believe they would use this this Molex brand 430250400 Micro-Fit 3.0 Receptacle Housing, Dual Row, 4 Circuits.
https://www.molex.com/molex/products/part-detail/crimp_housings/0430250400#
Pepwave and Cradlepoint use the same GPIO connector and I’ve found the Cradlepoint ones cost less. They do come in different lengths, here’s an example.
Also you can just cut the transformer off the cable that comes with it and use that as a 12v pigtail.
What are the 2 extra wires used for? I understand that 2 of them are for power/ground.
Hi, found this info I had sent my tech when we started using the HW3 Mini models. Hope it help, I believe I got it from the manual. May be other input/output options with the newer firmware. Can be confusing since when cutting the transformer cable white is the negative power and black and red can be tied together for the positive.
The GPIO connection has three inputs. Two are for the + and – power inputs and the third is a + ignition/key on input for installation in automotive applications.
We really only need to connect the + and – power connection but when the transformer wire is cut it includes the third ignition wire so is easiest to just go ahead and also connect to + power supply.
Below is a diagram of the GPIO connections when used in an automotive application. The wire colors correspond with an option cable we don’t use.
I had the same issue - the HW1 model has a 2 pin connector supplied as a terminal block (so you can just insert bare wires and tighten the screws).
I upgraded to HW3 (to get eSIM support) and this 4 pin connector is not as nice.
My solution was to use Anderson powerpole connectors : I cut off the cord from the supplied AC->DC adapter, and put power poles on both, and on my 12V RV system. This allows me to use the BR1 in the RV or at home:
And just to confirm what others have said:
Wiring has unusual colors:
- White = ground
- Black = +12V
- Red = +12V (ignition sense – if not needed, just tie this to black)
It’s probably good you reminded everyone of this. The colors are indeed unexpected for the given use.
