When is the MAX BR1 firmware update going to be released? I heard it was supposed to be right around now but haven’t seen any news yet.
Hello, Which firmware upgrade are you referring to? There is a beta build that can be located here inside of the Eval Guide.
Otherwise the fully tested and current firmware can be found here:
I’m looking to patch the bug with the MAC Address ACL on a MAX-BR1-LTE-V unit. I was told that there would be a firmware update released around the end of NOV '13. Not real keen putting a beta version online facing the internet, and don’t have a test unit to place on a Backend lan or DMZ to safely evaluate it. Is there any word on when the beta test will be concluded ?
