Probably pretty basic answer to this question, but I am new with the Max BR1.
Is there a way to see how much data is being used on the sim cards, through the Device management, InControl2 panel?
Thank you
Thank you
Sure. Navigate to the device in IC2 then click reports > Bandwidth and Usage Report
Then you can run reports on usage for all wans or per wan:
Thank you. Very helpful
