I have two LTE connections - AT&T and Sprint. AT&T is lenient and wherever you put their SIM card, the LTE connection will work. Sprint is strict - their SIM card will work only in their hot-spot device and nothing else. I currently use MOFI 4500 router with AT&T SIM card inside. I configured its Wi-Fi to connect to Sprint-provided Wi-Fi hotspot. And then set up the failover so it routes all traffic via Wi-Fi to Sprint hotspot if AT&T is determined down.
Is it possible to configure MAX BR1 Classic (or any other Peplink product) to use Wi-Fi in client mode (not AP mode), and connect to a Wi-Fi network, and then perform the failover between the Peplink built-in LTE connection and the Wi-Fi connection?
I want to get rid of MOFI 4500 and I’m looking for a good replacement.
Yes. In Peplink terminology this is WIFI WAN. Any wifi enabled MAX product can do this although the BR1 mini needs an extra license to enable it (along with wired WAN).
I have one more question. I use MWAN3 feature for failover on my OpenWRT router. AT&T via built-in LTE module is primary, Sprint via Wi-Fi is secondary. Plus I have a couple rules where I route traffic the other way - Sprint is primary, AT&T is secondary. My children’s computers go through it (so they don’t affect they speed of my Internet, which I need for work), and TVs (because AT&T throttles some media traffic by IP - namely YouTube but maybe some more). Does any of Peplink products support an equivalent of MWAN3?
OK. I am not familiar with that plan. Curious, however, that they insist on using a certain router. We’ve not experience that inflexibility here (although I admit to having been frustrated a few times when things did not work after switching a SIM between devices. Then the “oops moment.” If Sprint’s service works for you the price is an absolute “steal.”
(And, I see @MartinLangmaid already gave you the correct answer to your question. --good.)
