On MAX-BR1-T units with FW 6.1.1 1524 I have a primary wired WAN connection with cellular as the second priority. Under cellular details I have the following options under “General Settings” set as:
Standby State = Remain Connected
Idle Disconnect = Unchecked
With these settings I would expect the cellular to stay connected but both the units “Dashboard” and inControl2 show the cellular in “Standby” and I cannot connect to the cellular IP for remote administration which I do have enabled.
Is there another setting I need to change to have the cellular not go into standby?
