Hi, I have Pepwave max BR1 with product code MAX-BR1-AE-T (international).
I would like to visit US, please help me which carrier in 3G (HSDPA, HSDPA+, HSPA etc) will it work with?
AT&t? T-mobile? Sprint? Verizon? ???
I will mostly visit some LOW-POPULATED areas in CA, NM, AZ, NV.
Thanks.
The Pepwave MAX BR1-AE-T supports 800/850/900/1900/2100 3G MHz frequencies.
Unfortunatly I do not know which providers uses what frequencies in which region.
Based on the supported frequencies, Verizon, AT&T or Sprint would be the safest ways to go.
This model does not have CDMA capability so it will not work on the Verizon & Sprint networks. You should be able to get a 2G/3G connection on AT&T or T-Mobile though.
