Hi
i have two 493 poynting antennas
in which port i mast connect them for best results? A,b,c,d ?
Also how this ports work with separate antennas?
thanks
In firmware 8.3.0 , we have introduced the 2 x antenna mode for the device that can support the feature.
You can refer some of the information as below :
Reference discussion on how to enable the 2 x Antenna mode:
https://forum.peplink.com/t/firmware-8.3.0-rc-3/63a2d6709097890cac40e9ba/45
What about the flex modules that end in -1GLTE-G and -15GH for the Balance 20x? Also, what about the transit and others with the Cat-18 that has Main 1A, Main 1B, Aux 1A, Aux 1B? Or can one just ignore the two Aux ports?
