We are evaluating the MAX-BR1-LTE-E-T model in Hong Kong.
Is it possible to monitor or find out which frequency band the BR1 is locked to during the operation?
Any function in the BR1 can support this?
Or is there a frequency band selection function that can manually assign a frequency band in the BR1?
Current firmware for MAX-BR1 web admin doesn’t show the connected frequency band info for the cellular connection. You may send your request using the following link as feature request.
Regarding to the band selection function, you can enable it by referring to the attached screenshots.
