Can you please confirm the power connection ports on the MAX BR1/2
In the attached photo, are the connections
A. - - + +
or
B. - + - +
I’ve been using the DC plug in port but sometimes if this is moved it causes the router to reboot, hence I’d like to use the screw down terminals.
Many thanks
Gary
If Pins were number left to right 1-4
- DC Negative (black / cold)
- Low Voltage Output
- Low Voltage Input
- DC Positive (red / hot)
so -//+
Hi Martin,
Thanks for the reply, so just to confirm as I’m using a 12v system, and only the two wires
Left to right
- Neg/Gnd,
- 12v Pos
What exactly are the Low Voltage Output and Low Voltage Input for
Gary
Yes that’s right.
They are general purpose input output pins.
