Is it possible to use MaxAdapter wtih BYO and how I can do this, at is seems to me it is not yet included ?
Regards
Regards
Please refer to this FAQ - Peplink | Pepwave - Forum. Ensure you connect the MAX Adapter as a cellular WAN. Then you may download the eSIM profile via InControl2 as below.
So it is impossible to use modem own ESIM, without some more peplink devices?
it is little unclear for buyer, and you should better explain for max adapter, how it is possible to be done, and that this can not with windows / linux without some more pepink devices ?
May you tell me, may I use Peplink 310 5g, and connect this modem over USB, and than this to be done ?
Also I had one more issue, with warranty. I bought new peplink device modem but it stated that warranty expired. I ordered new one but was wandering may you check what is with initial warranty. , but I would like to get an response about warranty for new device, serial number> Balance 310 5G 2001-88CD-77C1
You may use Balance 310 5G with MAX adapter for BYO eSIM deployment.
For the warranty status, please do product registration here - https://www.peplink.com/support/. If you purchased via Peplink partner, you may get help from them to do the registration.
It is possible to download eSIM profile to MAX Adapter if you use MAX Adapter with Microsoft Windows. Ensure you set eSIM in MAX Adapter with Peplink Connection Manager then use Windows to download the eSIM profile.
Also same problem with windows. I can give you address and activation code if you would like to try?
