I have purchased a Pepwave Max Adapter 5G to add 5g to our Max HD4 LTE. When I plug the Max Adapter into the HD4 via the usb port is stays hung on “connecting” it discovers the usb and the max adapter it just will not connect. I have restarted, reconnected the unit multiple times.
Do you have any suggestions how to get it to connect? or why it will not connect?
I have this same issue. I have tried downloading the above firmware but still no luck. I am now running the GM 8.1.3 and still having the same issue. Any help would be much appreciated.
I have a potential similar situation. I have a MAX Adapter 5G connected to an HD4 MBX and with AT&T it won’t ever go beyond “Connecting”. Verizon and T-Mobile connect fine. I’m in a very good signal area, and the same SIM can be used in the HD4 MBX on any modem and works fine.
Is there a firmware version for HD4 MBX that I can test?
