Hi All
Can someone please confirm the exact requirements for the Power Supply for the Max 700 Router.
I have one here which I believe may be the Power Supply but I want to confirm this before I go plugging it in.
Hi All
The power requirement for MAX 700 is 10V - 30V DC. You can check on the specifications here, http://www.peplink.com/products/max-cellular-router/pepwave-max-700-hd2-specs/.
Regards.
Yes i understand that.
I have a Power Supply here that is 12v - 3000mA and I want to make sure that is the right one
Yes, we are using that power supply to power our MAX HD2, the same platform with same power requirement with MAX 700.
