I have a couple questions about the PoE support on the Max 700.
I see that it allows a PoE add on. How does that work? Is that a software key? Does it require additional hardware? Can I retrofit it to an existing Max 700 in the field if we decide to add PoE devices in the future?
Can I get power on a WAN port? I’m curious if I could power a high power external radio like the Ubiquiti Bullet M, WiFi Ranger Elite or maybe a satellite internet setup with it. (Though most likely the External Wifi as WAN antenna would do the job, just curious)
Thanks.
