Maritime 10 with a MAX BR1 PRO 5G
For a 4G/5G system project, I would like to combine the MAX BR PRO 5G modem with the Maritime 10 antenna.
For that I would have liked to know what was the maximum distance between the modem and the antenna so that the signal is always usable. I couldn’t find this type of information in the modem’s datasheet.
Are you using other antennas too? The MR10 antenna is a single input/element antenna with a single N Type connector on its base. You would need 4 of these for a BR1 Pro 5G with adapter cables to go from the N Type to the SMA connectors on the BR1 Pro. Alternatively consider the MR40G antenna which is designed for this really.
5M is my recommendation. Much more than that and you need very high quality cable indeed. Cable guide here: https://download.peplink.com/resources/peplink_cable_details_datasheet.pdf
