Management, what to choose?
Hi, I am new to peplink, so sorry if this is clear for many users,
how do you manage or remote manage your router,
I have a peplink app: ‎Peplink on the App Store
I have a in control app: ‎InControl for Peplink on the App Store
I have a router utility app: ‎InControl for Peplink on the App Store
I have in control site: https://mars.ic.peplink.com/
I have VPN accès to router: 192.168.xxx.xxx
I see features that are available in one place and not in the other an vice versa, having my self to go to multiple managing places to operate them,
Is there any unified place to manage and control everything?
Hello…
I prefer VPN, direct to device… but…
Sometimes when I am in a public transportation, VPN not work well, so I use:
Incontrol APP (iphone version looks better then a android version)
When I am at remote office I use Incontrol site. (for everything)
Okey, thanks for the advice, Definitely I think this all needs to be homogenized,
Some features are not available in one place and you need to go to the other,
EG: Starlink stow, you can only stow it via a clod service, once you stow it, you no longer have internet access, and then, you can not unstow it, unless you have a secondary connection. This should be available as a local router feature
Hi @alnavasa,
Managing single router:
Web Admin Interface - 192.168.xxx.xxx
This is where you can configure all router settings, and view reports and logs. The device you use to connect must be on the same network.
Peplink App
This is our new app allowing you to manage your router anywhere. It currently has features like swapping your WAN priority, configuring your SFC, topping up licenses, viewing WAN status & usage reports, and getting notifications. While it doesn’t include Starlink stow yet, it is in our roadmap and we will continue to introduce new features.
Router Utility App
Unlike the Peplink App and InControl, this app communicates directly with the router. You can view basic router information like WAN status and configure your SFC.
Managing multiple routers:
InControl Cloud Management
You can manage as many routers as you desire and organize them in your organization, and it lets you view aggregated reports and apply bulk configurations.
InControl App
This provides a concise view of InControl Cloud Management on router information such as connection status, client lists, and event logs at the fingertips.
If you have a single router, I recommend registering your router to the Peplink App for features like changing WAN priority, configuring SFC, and getting notifications on WAN status. This also automatically creates InControl for you so you can immediately take advantage of utilizing the Starlink Stow and Unstow functions.
Okey,
I wasn’t able to change wan interfaces, they kept popping back to other place in the priority list, looks like they can only be arranged via the app, not the router interface.
You’re right. I should have mentioned that for features like WAN priority and SFC available in the Peplink App, the app’s configuration will override the settings in the Web Admin Interface. Please configure them through the Peplink App.
Yeah, but if I have no network (left coastal shore) and I need to change priorities, or wan interfaces, I can’t, not a fan of it.
