Making Config Changes via InControl but not using Remote Web Admin
I just realized I left a couple devices in 2nd and 3rd priority that are not turned on in the coach after putting it into storage. The RSRP is around -120 out there so the connection is extremely slow. Remote Web not really an option to use, but I don’t see a way to move those 2 devices to Disabled without driving way the heck over there. Is there a way to manipulate that thru IC without using the remote web stuff? Thanks, Bill
Apparently I cannot use Incontrol2 to make config changed based on all the responses…
You can now push a new Outound Policy to the device from IC2 that would do what you want.
You can now work in the latest IC2 release with different WAN Configuration Profile pushed from IC2. Combine this with the GEO Fencing functionallity and you can based on tags when leaving or entering a GEO fence, push different WAN Configuration profiles when you know the RSRP will be bad at that location.
Let me know if you need some help with that.
