hye, i want to ask, how can i make the wifi wan on 2.4ghz and 5ghz can communicate with lan? im using peplink max duo pro, this is my network diagram. when i try to ping wifi wan to lan, it cannot ping
Hello.
Can you manage network routes at your WiFi router (192.168.0.1)?
You need to add to your WiFi router a rule like this:
- 192.168.8.0 netmask 255.255.255.0 gateway 192.168.0.154 (Peplink WiFi WAN)
Also… try to fix at your WiFi router to always provide ip 192.168.0.154 to Peplink - Disable NAT at your Peplink WiFi WAN.
okay?
thanks for the reply! ill try it first and ill let you know how it goes. thanks again ![]()
Please… look at your wifi Router… the ip network address is at your LAN side.
Not at your WAN side.
Please… correct the interface to be LAN.
Peplink router is at ip address 192.168.0.158? Please, check this ip at Peplink interface.
About Peplink.
Correct… IP forward.
please… uncheck the " use default lan ip address … "
Regards,
thanks, i will check
