- The firmware on my router is updated but it says it will not support further firmware updates- only maintenance releases. Does the maintenance release mean it’s still valid to use? I
That would be up to you and your company’s policies?
Yes, thank you but what does the maintenance release provide that’s different from firmware release? Thx
typically that means bug fixes and security fixes, not new features/updates.
Awesome - thx
