hello, I have a speed problem with my router I have two cable connection 250Mbit/s each. when i do a speedtest i get 50mbit/s with my balance 305. Before it was correct and I changed nothing in the configuration
do you have an idea of the problem?
than you
I would test the cable connections individually for the next step to help narrow this down.
yes i have test 2 modem and i have 250mbit/s
To clarify, going through the Balance 305 you get 250 Mbps with either connection but only 50 Mbps when utilizing both at the same time? Please open a support ticket with us here so we may investigate.
are you using drop- in mode?
