I was changing wifi name and password. somehow i messed up the password. I cannot connect with wi-fi. I just used device first time today and do not have a backup file. What should i do?
You can either do a factory hardware reset put pushing a paper clip into the reset hole on the front and holding in for 10 count. Or you could create an account at incontrol2.peplink.com and add your device serial there then you will be able to login to it via IC2 and change the password.
you rock. Thank you Martin. I set up the account. easy!
thanks again!
This topic was automatically closed 182 days after the last reply. New replies are no longer allowed.
