Currently I have a Balance One and several AP’s within our office and the system works great. We just developed another building that is across the road from us (about 150ft) and I can’t run any physical connections across. In lieu of having another service brought into that location what would be the best way to “extend” my network to serve the building across the street? I would like to use a Peplink product, but I’m open to whatever is the best route.
You could use a Ubiquiti nanostation bridge to do a layer transparent bridge across. That would be my first choice. Likely a pair of Loco5AC’s UISP airMAX LiteBeam 5AC XR - Ubiquiti Store
Hello @jakebdb56,
There are a plethora of PtP (Point to Point) linking options out there. @MartinLangmaid has mentioned one brand, you can also use the Cambium ePMP range or the Mimosa range & Siklu range (all brands offering varying pricing and features to be considered), these are all bands we currently work with. We have previously worked with other brands (including Ubiquiti), though have moved away from those for various reasons. @Tim_S has mentioned the Peplink way and this also works well for keeping everything within the same ecosystem.
I suggest you engage with your Local Certified Peplink Partner, they most likely will have someone on their team who is familiar with PtP Links.
