Login and password for Connecting to FusionHub’s Web Admin Interface
I’ve been able to deploy and connect to public IP of FusionHub on Vultr. Then I follow the steps in the installation guide which says: “access the Web admin interface by entering admin for both the username and password”. And I’m not able to get as I get this message: “Invalid Username or Password.”
Any ideas what is the default login and password now?
Thanks in advance,
Igor
The default password of FusionHub on Vultr is Instance Id. Please refer to page 104 of FusionHub Manual.
That helped, thanks a lot!
I’ve redeployed it on GCP and as I understand the password must be Instance Id but combination of Login: admin and Pwd: Instance Id doesn’t work.
Any advice would be much appreciated!
Found it! It is in the VM instance.on the very bottom under Custom metadata.
