Is there a way to log somehow users downloads (URLs) on Balance One??
You can enable url logging under Network/Firewall/Content Blocking
You will need to use an external server to store the data. We use Synology servers.
Does it slow down particularly the router?
We have not noticed any negative effects
Great stuff! Ito works on both our QNAP NAS unit and Solariswind free for Windows! We opted for the Solariswind server as it shows a better viewer. THANKS!
Last question: is there a way to customise log message ? For instance remove some content from message?
This should be done at SolarWinds end.
