Hello guys,
I have a Balance 380 router with 5.4.9 firmware and I need your help.
I want to be able to log my outbound traffic because we are being listed in spam lists and I want to be able to view the log file after a while in order to check if anything weird happened.
Is this possible and how?
I cannot look at the active sessions all the time because I don’t know when the problem will occur…
Thanks in advance
Yes this can be accomplished by setting a Outbound Firewall rule and enabling firewall event logging. This can be defined for all traffic, by range or single ip. I would not recommend keeping this on all the time as it will use a lot of bandwidth but should be fine for a little while. Once event logging is enabled you will be able to view the reports via the event log.
Thanks a mil Jarid!!
It worked!
Now I can trace that ZeusBot!
Thanks for the follow up and good to hear that everything is working! As always, should you have any questions at all don’t hesitate to ask, were here to help.
Best Regards,
Jarid Petermann
The Peplink Team
