I am using a Balance One router that has an attached AP Pro AX. WAN is Starlink only. This is on a mobile trailer that is used by the customer & 3rd party vendors (namely trucking companies). I have an unrestricted use SSID called Enterprise for company employees. That works fine. The issue is with the SSID called Trucking; I need to lock this SSID down to only work with particular domain names. The truckers only need to be able to access URLs related to picking/dropping loads on the location. Otherwise the bandwidth will be swamped with PornHub, among other issues. I’ve set up the lockdown rules for the SSID (see attached photos), but I keep having trouble with it. I try to connect to the Trucking SSID, but it never fully connects. It keeps acting like it is handshaking, but it never actually fully connects. Meanwhile I have no issues at all with the Enterprise SSID. Have I configured the Trucking SSID for the application that I’m describing above? Is there something I am overlooking?
