The BR1 is not designed to do load balancing, it is a fail-over cellular router with session persistent PepVPN capabilities. If you need load balancing on a mobile product, then you want to look at the MAX 700, MAX HD2, or MAX OTG.
Can I request that Peplink edit their website - It says in your first paragraph right below a picture of the BR1:
“The Pepwave MAX mobile router gives you the ultimate in mobile connectivity. With the ability to combine a variety of wireless services, the MAX gives you maximum reliability through automatic link failover and scalability with multi-WAN load balancing and SpeedFusion™ bandwidth bonding. The Pepwave MAX brings wireline reliability to environments where no other solution can”"
This is completely misleading. I am a Peplink partner and am in the embarrassing situation now of telling the client I am with at the moment that the 700 euro unit they purchased has less functionality than the 35 euro TP-LINK TL-R470T+ they had previously.
How is the SpeedFusion supposed to work on this unit if it cant load balance???
How come load balancing is present on the MAX OTG and its a significantly cheaper unit?? (less than half the price!)
Although MAX BR1 does not support load balancing, it has a embedded world-mode 3G modem and a rugged metallic housing that MAX On-The-Go does not have. Here is a helpful comparison chart.
If you need a MAX model with load balancing for your customer, we can offer you a trade-in for your MAX BR1, please contact us.
