Which Enterprise Balance Routers support Link Aggregation?
With many WAN inputs, 1000Mb LAN outputs and internal speeds rated higher, I really need to use link aggregation to a switch with higher capacity.
What does the * beside the 2500 refer to?
Thank you very much
