Dear Friends,
Kindly clarify me on below scenario
One of our customer is looking for Link aggregation between Branches. All the ISP are different.
Scenario 1
HO And Branch office having 4 Mbps(1:1) MPLS and 2 Mbps(1:1) Point to point line. Here the following point need to clarify
Can Peplink Balance aggregate the link between MPLS and P2P line through SpeedFusion with different ISP.
Is there any compatibility issue to create SpeedFusion between MPLS, Leased Line, P2P and Broadband etc.
If we create a SpeedFusion VPN using both the ISP then can we have 4 + 2 mbps = 6 Mbps download or upload speed.
What is the Max upload or Download speed if we transfer a file between HO and Branch using SpeedFusion VPN
Scenario 2
HO And Branch office having 4 Mbps(1:1) MPLS, 2 Mbps(1:1) Point to point and 4 Mbps(1:1) Internet line. Here the following point need to clarify
Can Peplink Balance aggregate the link between MPLS, P2P & Internet line through SpeedFusion with different ISP.
Is there any compatibility issue to create SpeedFusion, between MPLS, Leased Line, P2P and Broadband etc.
IF we create a SpeedFusion VPN using all the ISP then can we have 4 + 2 + 4 mbps = 10 Mbps download or upload speed.
What is the Max upload or Download speed we can get if we transfer a file between HO and Branch using SpeedFusion VPN
Thanks & Regards
Sreedhar NC
Scenario 1
1.Can Peplink Balance aggregate the link between MPLS and P2P line through SpeedFusion with different ISP.
Yes.
2.Is there any compatibility issue to create SpeedFusion between MPLS, Leased Line, P2P and Broadband etc.
Bonding requirements s below:-
Latency
- Latency for each link must lower than 1000ms.
- Different of latency between each link must lower than 150ms.
Bandwidth
- Slowest WAN link must has at least 15% bandwidth of fastest WAN link.
3.If we create a SpeedFusion VPN using both the ISP then can we have 4 + 2 mbps = 6 Mbps download or upload speed.
There are lot of dependencies. Ideally If both WAN links condition are good and having dedicated bandwidth, you roughly can get throughput 4.8Mbps (after minus overhead).
4.What is the Max upload or Download speed if we transfer a file between HO and Branch using SpeedFusion VPN
Please find the answer in question 3.
Scenario 2
1.Can Peplink Balance aggregate the link between MPLS, P2P & Internet line through SpeedFusion with different ISP.
2.Is there any compatibility issue to create SpeedFusion, between MPLS, Leased Line, P2P and Broadband etc.
3.IF we create a SpeedFusion VPN using all the ISP then can we have 4 + 2 + 4 mbps = 10 Mbps download or upload speed.
4.What is the Max upload or Download speed we can get if we transfer a file between HO and Branch using SpeedFusion VPN
Answers are similar to Scenario 1. You roughly can get throughput 8Mbps (after minus overhead).
Hi Sreedhar,
You may want to refer to our Design Lab on the similar deployment.
Thanks and regards.
