Limitations of Peplink Router API for Router Configuration
I’d like to use the Peplink Router API to apply various configuration settings such as port forwarding, but I can’t find any API calls in the documentation that would do that. There don’t appear to be many options available for the API, so I was wondering if the documentation is out of date or the API is still currently limited. Are there any alternatives for automating the process of configuring routers?
Not everything is exposed for router api calls, and they slowly add more.
other configs can be applied as group policies via ic2 such as outbound policies, firewall rules and more.
Another option is tou could save the config and do bulk config to help if you are trying to do a lot of units.
Ooh, I didn’t know about bulk configs. That should be really helpful! Thanks!
