Will the clients be connecting via wifi or will this be via ethernet? If the clients are connecting via wifi you can do this using Captive Portal you can limit the amount of bandwidth on a daily basis.
is it possible to limit the traffic data on a monthly basis? I’m using SIM with a commerciale limit of 30GB/month and I need to stop the service when we reach this limit.
You can enable Bandwidth Allowance Monitor under the cellular WAN settings and define your Monthly Allowance for the device. The Start Day can also be changed to match your billing cycle.
thank you Zack!
I have some other questions about the captive portal:
Where are the data stored; are your data center in EU and compliant with GDPR if needed?
Because of the Italian law we need to store the log data for 1 year and we understand that you store the log data for 3 months; is it possible to extend this period? if not, how can we manage the data export?
Is it possible to customize the Captive Portal with the insertion of personalized Term of services and Privacy policies?
Where are the data stored; are your data center in EU and compliant with GDPR if needed? Data is stored on AWS on US servers. We have T&C’s and processes which are compliant with GDPR for the handling of this data.
Because of the Italian law we need to store the log data for 1 year and we understand that you store the log data for 3 months; is it possible to extend this period? if not, how can we manage the data export? I am assuming the requirement is based around the web sites access by the clients. This can be recorded via the device by sending this to a separate syslog server.
Is it possible to customize the Captive Portal with the insertion of personalized Term of services and Privacy policies? We include a mandatory section which outlines how Peplink store and use user data, along with a section where the provider can insert there own Terms of Service and Privacy policies.
do you support the social login? We support Facebook, Google, WeChat, twitter,LinkedIn, Instagram, Sina Weibo social logon.
