Hi all.
what do happens when the following licenses expire?
and
can you explain me that mean Warranty / Subscription Expiration Date.
Regards
Hi all.
and
Regards
Here is the imagen
The Warranty expiration date is the date that the hardware warranty/InControl2 subscription expires. Depending on your models, you can either go with an extended warranty which includes the InControl2 subscription or an InControl2 subscription-only in order to keep using InControl2. If you do not renew then the devices will continue to operate normally but you will lose the ability to manage them from InControl2. Thanks.
What options do we have to renew licenses / warranties? Only through a vendor? Directly with Peplilnk?
You can go through a certified partner or Peplink directly, there is a link to the store on our site. Thanks.
