License status show on Web UI
Hi Support team,
Due to there has few optional license such as: WAN port license(balance) and SpeedFusion bonding license(max router) but no display any description on Web UI.
Is that possible to added license status(in used) column in status page β†’ device β†’ system information?
That will make great help when end user want to auditing software license.
Thank you.
+1 for this request.
Currently, it is not easy to see if a feature add-on license has been activated on a unit through InControl2 or the Wed Admin GUI.
Would it be possible to add a field in the device details (and / or status) showing which add-on license is activated on a unit?
Thanks!
We have also many questions to that from our costumers
so +1
Do you think this helps? Please refer to the screenshot below.
Hi TK,
I know this Info-field, but if you are on the local GUI, because you have e.g. no rights (or no subscription) to InControl it doesn’t help.
If you install a licence local on the GUI you don’t see any information about that after you pressed Apply.
Dennis
