I have a Balance One router with a trial Speedfusion cloud key enabled and I plan on purchasing a top up plan once this runs out. I would like to use the WAN smoothing and FEC features but only on the Speedfusion cloud VPN. Do I need an additional license for this? If so please direct me to the correct one.
The “add-on” features are available across the SpeedFusion Cloud licenses (trial or paid), you are safe to order to top up plan(s).
I have an active speed fusion cloud license but WAN smoothing is not available when I edit the VPN profile. How can I enable this feature?
082937|507x500](upload://aTNHAV7d60VGNKgobaVegqQ3qUk.png)
It’ll work as soon as you create the sub- tunnel. In the example below I checked on the “2” just to the right of the “1 - Default” and another screen popped up and that sub-tunnel is seen ready to be configured.
Thank you for the response. I have created and applied a sub-tunnel and still no WAN Smoothing option. Please see screenshot. What am I missing?
Looks like you might be hitting the bug as the other user reported in this post, target to be fixed in next major firmware release.
I’m having this issue as well on my Balance 20 with firmware 8.1.0 Is there a plan to fix this issue?
